What's the difference between NEX-3 and NEX-5?
Which one is best for creating a shallow depth of field?
Sarcast
Sat, 12 Mar 2011 23:31:52 +0000
I'm not sure what's different between the NEX-3 and the NEX-5. I think only the video quality differs. Otherwise, they are pretty much identical.
It's not the camera that does changes the depth-of-field. It's the lens. You'll want the 18-200mm lens and use it at the 100 to 200 mm range. The depth is shallowest at 200mm.
Sat, 12 Mar 2011 23:46:20 +0000
I was looking at the rebel yesterday. For that kind of money, might ad well go with a regular Dslr, no?
Sarcast
Mon, 14 Mar 2011 15:39:34 +0000
What you trade-off in style, you gain in function. You decide.
The NEX-3 and NEX-5 has style, which I wrote in "Unique and Unconventional Looking Digital Cameras". The EOS definitely have function.
I noticed that the 60D on Amazon is a very good deal; $1000 for the body. And I would suggest the Canon 28-135mm IS lens for $500.
The NEX-3 and NEX-5 with a 18-200mm lens is probably a better travel camera. If you hardly travel, then the 60D is better for you.
The FujiFilm FinePix HS10 is also an awesome travel camera, without the style nor all the functionality. But with a 24-720mm zoom lens, you'll have really shallow depth-of-field. My review: FujiFilm FinePix HS10
Mon, 14 Mar 2011 17:14:01 +0000
You like the nex3 or 5? and which 200mm lens to get?
Sarcast
Mon, 14 Mar 2011 19:52:03 +0000
identical.
There is only one 18-200mm lens for this camera:
Sony Alpha SEL18200 E-mount 18-200mm F3.5-6.3 OSS Lens (Silver)
Mon, 14 Mar 2011 21:56:05 +0000
$900?!
Sarcast
Mon, 14 Mar 2011 22:50:12 +0000
What!? Too expensive?
Mon, 14 Mar 2011 23:05:25 +0000
you don't thinink so?
Sarcast
Mon, 14 Mar 2011 23:25:23 +0000
No. Most photographers knows that good lenses cost more than cameras. And as you asked, what lens will get you the blurred background. And that's this lens. It's not the camera.
But as I mentioned before, if you are cost-conscious, you should consider the FujiFilm FinePix HS10 for $499. It's got a zoom lens that is 3.5x more magnification than this Sony lens. So you'll get plenty of blurred backgrounds.
However, don't count on being as stylish with this FujiFilm as you can be with the Sony. And don't count on this $499 combination beating the $1000 60D and the $500 28-135mm lens in term of image quality and performance.
You practically get what you paid for.
Tue, 15 Mar 2011 05:32:14 +0000
did I send you this link?
Review: Nikon Coolpix P7000:
http://www.electronista.com/articles/11/03/13/our.review.of. . . .
it can create that shallow depth of field
Sarcast
Tue, 15 Mar 2011 17:08:52 +0000
does this come with everything I need? I'll just get the lense later or something. it can do more and it's only $70 more.
Sarcast
Tue, 15 Mar 2011 17:11:44 +0000
Yes. The 200mm focal length, on the Nikon Coolpix P7000 will provide more shallow depth-of-field than its 28mm focal length. However, I suspect that this camera has a small sensor, so it will not have as shallow depth-of-field as the Sony NEX-3 and NEX-5, with an APC-sized sensor, at 200mm focal length.
I think the Canon T2i camera body is sufficient and plenty good for. However, the 18-55mm lens will not provide the shallow depth-of-field that you are looking for. You'll need the 28mm-135mm IS lens at a minimum. I say save your money and get the Canon T2i body only. And purchase the Canon EF 28-135mm IS lens along with the body.
Tue, 15 Mar 2011 23:24:49 +0000
ouch...
Canon Mum on EF 200-400mm f/4 L IS Zoom Lens Details
$7.5K?
Sarcast
Tue, 15 Mar 2011 23:44:21 +0000
423 Users Online
